Help to identify part-number - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: Problems & Troubleshooting (https://www.comfortforums.com/forum-36.html) +---- Forum: Troubles (https://www.comfortforums.com/forum-77.html) +---- Thread: Help to identify part-number (/thread-3917.html) Pages:
1
- rportela - 08-11-2014 [user=4494]Vangelis[/user] wrote: Quote:Looking at that board, the only functionality I could see it doing is...I think that would be the case, but I\'m not sure why this board was needed. What should I read on the sensor output, when the circuit is closed ? - Vangelis - 08-11-2014 If you have a continuity setting, then the Multimeter will beep when you get a closed connection, otherwise use the resistance setting and check for close to zero ohms. Vangelis - rportela - 08-22-2014 OK, managed to get a replacement. Its again operacional. Still don\'t know the origin (maker) of the board.... |
