error reading .cctx file - Printable Version
+--- Thread: error reading .cctx file (/thread-3962.html)
Pages: 1 2
- juwi_uk - 09-09-2014
Probably a longshot but have you tried the \"Update Defaults\" action from the File menu to download a new set from the Cytech Website?
- meep - 09-09-2014
Quote:Probably a longshot but have you tried the \"Update Defaults\" action from the File menu to download a new set from the Cytech Website?
Hi Julian
Unfortunately, I cannot get application to launch (in order to access the file menu)
When I select the template on initial startup, I am presented with the above option. Clicking OK quits comfigurator .
Peter
- ident - 09-19-2014
Can you check if you have Windows XP SP3 with .NET Framework 3.5 SP1
This is needed for Comfigurator to work on XP
See this topic http://www.comfortforums.com/forum20/3987.html
