Fibraro Universal - Printable Version
+--- Thread: Fibraro Universal (/thread-4097.html)
Pages: 1 2
- Ingo - 01-28-2015
Are there plans to update the discovery of this Binary Switch/Sensor so we can select either Counter or Sensor depending on the capabilities of the device? I fear more devices from Fibaro is going that route, just look at their RGBW controller, it has multiple analogue inputs, RGB controller etc. Even their Door/Window switch has a temperature sensor - of which I plan to buy a few soon.
Ingo
- slychiu - 01-28-2015
[user=436]Ingo[/user] wrote:
Quote:Are there plans to update the discovery of this Binary Switch/Sensor so we can select either Counter or Sensor depending on the capabilities of the device? I fear more devices from Fibaro is going that route, just look at their RGBW controller, it has multiple analogue inputs, RGB controller etc. Even their Door/Window switch has a temperature sensor - of which I plan to buy a few soon.
UCM/Zwave does allow mapping of Counter or Sensor based on the command class supported by the device
It is only for Multichannel class devices where each channel supports  a different  class that this is not possible without a complete redesign of the UCM/Zwave firmware which is not likely to be in the near future
By the way the Universal sensor was found not to support the multilevel sensor class as mentioned in the above post. What value does it report then?
