UCM/ETH03 New Features - Printable Version
+-- Forum: These Forums (https://www.comfortforums.com/forum-1.html)
+--- Forum: NEWS & Announcements (https://www.comfortforums.com/forum-25.html)
+--- Thread: UCM/ETH03 New Features (/thread-4146.html)
Pages: 1 2 3 4 5
- wexfordman - 03-08-2015
Well, eth03 arrived, and installed and everything working.
I live in a rural area and have no phoneline, but comfort work over my broadband, so its great to be able to receive notifications via email, also the 2 ports is a great improvement.
Some question/queries on it though.
1) The inability to use google apps as my smtp server is a bit limiting, I did use the sugested service smtpcorp that cytech proposed and this works, but is limited to 20 emails per day. Would run out of that just doing some testing. Any plans to allow google mail functionality
2) Username character limit is a bit irritating, I have had to establish a dedicated email to work around this.
3) Is it possible to add some default ext to the outgoing email ?
Can see loads of potential in this, very keen on the webserver demo to see what plans are around it.
Also, are there plans to integrate the etho3 into the app, to allow the app take push notifications from comfort, ie, for comfort to talk direct to the app ?
- juwi_uk - 03-08-2015
Presume you mean eth3 arrived. Smile
Doh!!
Yep sorry
- slychiu - 03-08-2015
Quote:1) The inability to use google apps as my smtp server is a bit limiting, I did use the sugested service smtpcorp that cytech proposed and this works, but is limited to 20 emails per day. Would run out of that just doing some testing. Any plans to allow google mail functionality
Google and yahoo mail server require encryption which is not done right now (but may be considered in future)
You can pay a small amount for practically unlimited emails
Quote:2) Username character limit is a bit irritating, I have had to establish a dedicated email to work around this.
I remember that the charatcetr length was increased?
Also it is often possible to enter username wiithout the domain
eg chiu instead of chiu@cytech-technology.com
Quote: 3) Is it possible to add some default ext to the outgoing email ?
what is default ext?
Quote:Also, are there plans to integrate the etho3 into the app, to allow the app take push notifications from comfort, ie, for comfort to talk direct to the app ?
We have been looking into it but it will not be in the very near future, as we have lost our resource for iOS app development
Hi slychiu
Thanks for the reply.
I meant default text, like in thr email header \"message from glenegare alarm system\" or something like that.
The character length still seems short for me, with  my email address its eamonnogorman at glenegare.com  it can be worked around though as you said.
RegardsEamon
- tman - 03-10-2015
There is a workaround I\'ve used for this before. You can do unlimited emails within reason.
1. Setup a dedicated gmail account for your Comfort system.
2. Set the ETH03 to send your alert emails to the email address you just set up.
3. Set the server to be aspmx.l.google.com and the port to be 25. Leave the username and password blank.
4. Log into the gmail web interface and setup a forwarding rule for your Comfort emails to the actual destination email addresses.
Google will accept emails from anybody using SMTP so long as the destination is actually a domain they\'re hosting e.g. gmail. Once the email has been accepted, the gmail server will then forward it to whatever other email address you want.
If you\'ve got Google Apps running your domain then create a new mailbox on your domain instead.
You should log into this gmail account at least once a year to make sure that it doesn\'t go inactive though. Google may delete inactive accounts.
- slychiu - 03-10-2015
I followed your instructions
set up a gmail address to send emails to
put aspmx.l.google.com as server port 25
user and password blank
I am looking for emails to the gmail address so I am not forwarding it
see the screenshot
But no email is received at the email address?
Am I getting anything wrong?
- tman - 03-10-2015
see the screenshot
That should be everything. Is there anything in the spam filter in gmail?
I\'m not sure why it isn\'t working for you. I can\'t test it at the moment as I\'m away and don\'t have an ETH03 with me.
- slychiu - 03-11-2015
No there is no spam filter, I used the same gmail address for the smtpcorp server
Perhaps someone else can check if it works for them
- Guest - 05-04-2015
The email facility is certainly a very useful one but I have discovered one slight snag though.
I set up a custom alarm type in Comfigurator using the previously unused alarm type no. 23. I renamed this in Configurator but neither Comfort Server Manager nor the email reflects this. It still appears as\'unused\' in CSM but the email states \'ForceArm\' instead, which corresponds to neither the CSM nor the Comfigurator description.
Could this possibly be rectified?
