Daylight saving time issue - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: Problems & Troubleshooting (https://www.comfortforums.com/forum-36.html) +--- Thread: Daylight saving time issue (/thread-4174.html) Pages:
1
- juwi_uk - 04-10-2015 So do we have to do that every time DST changes? - slychiu - 04-10-2015 You need to press Submit the first time that you use this SNTP function, r if you are upgrading from the old eth03 or CSM, or if you change time zones, eg you bnng the system to Africa Otherwise there is no need to submit again Check that the READ field is the same as the GMT offset field |
