Control actions not working in Velbus - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Third Party (interfacing to Comfort) (https://www.comfortforums.com/forum-5.html) +--- Forum: Velbus (https://www.comfortforums.com/forum-88.html) +--- Thread: Control actions not working in Velbus (/thread-4406.html) Pages:
1
- strickers - 02-13-2016 Hi, Thank you for the answers. I now understand the \'hours\' issue and have changed my response. All works well now ![]() I also understand the dimmer issue but the fix hasn\'t worked. I assumed I needed to create a new response and use that in the relevant dimmer counter response? Also I had to create the response manually as the wizard didnt have the correct actions. I have not yet converted a new cclx file to my phone. Do you need to import a new .jcrlccip everytime ANY change is made in comfigurator? Thanks. - tech07 - 02-14-2016 You have to convert the cclx file to send to your phone when the control menu is changed. If uncertain it is best to do it anyway The Response wizard does support these actions Select If in Add Conditions window, Attribute select Counter 010 (eg) > 0Press OK to exit the condition You will see If Counter 010 > 0Endif Insert New actionSelect Counter and Initialise Counter 010=255 save and convert the file to your phone Make sure the app is closed at this stage befiore reading the email and tapping the attachment Try the Light on buttonIf the light turns on check that the toggle state turns to ONThat shows that it is working and you can turn it off If you still have problem send the new file to suppprt@cytech.biz |
