Zone trouble - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: Problems & Troubleshooting (https://www.comfortforums.com/forum-36.html) +---- Forum: Troubles (https://www.comfortforums.com/forum-77.html) +---- Thread: Zone trouble (/thread-4462.html) Pages:
1
- qalsi.rahul@gmail.com - 06-04-2016 but continuity is ok.....I was short all zone and test system is ok what is the problem of zone troubling. - qalsi.rahul@gmail.com - 06-04-2016 please help me - slychiu - 06-04-2016 Quote:I was short all zone and test system is ok what is the problem of zone troubling. You mean you removed the zone wiring from the zones, and there is no zone trouble That proves that the problem is in the wiring or the sensors. There is a voltage on the wires Next re-connect the wires, use a multimeter to measure the voltage from Zone to Common (center pin on the terminal block) The zone shunt should be closer to the terminal block measure the voltage with the sensor closed. It should be 0 volts measure the voltage with the sensor open (ie door open). It should be around 1.3 volts These are the voltage when there is no other voltage sources on the wiires Let me know what is the voltage you measure on the affected zones - slychiu - 06-14-2016 I understand from the distributor that the problem was with wiring of the multiple zones and it has been fixed Wiring is the most important issue which causes the most problems in a system |
