Unable to connect to Pc - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: Problems & Troubleshooting (https://www.comfortforums.com/forum-36.html) +--- Thread: Unable to connect to Pc (/thread-4513.html) Pages:
1
- emabonacchi - 09-15-2016 Reading event log, only read 2% and date and time are uncorrect (for example \"88/01 05:37\"). - slychiu - 09-16-2016 If you can read the event log, it means UCM and Comfort both are working on UCM D9 Red is blinking and D10 Green is binking fast so it appears to be permanently on Right Click on Modules , Scan for Modules and check that all the modules eg Keypds, UCms are found Do a Write to Comfort with your cclx file - sonamg - 08-20-2018 Yes it looks like there is some fault do you have to use UCM with Firmware programming cable and look if you can upgrade the firmware? |
