Not quite working - Printable Version
+--- Thread: Not quite working (/thread-4625.html)
Pages: 1 2
- wexfordman - 11-14-2017
Hi Matt,
Just got my st hub today and running through the setup.
I have got to the point where the st app is finding devices, so I then go to select them (as an example I am just selecting one counter), I press save but i get a message saying device network id must be unique ?
Any idea what this could be ?
Also, just to get my head around some logic here,
a) To control a device, I run the comfort response ?
b) The state of the device is tracked by a counter value ?
If this is the case, how does ST hub know the status of the device, for example, I have response 33 to turn on a light, which it does, and counter 5 is updated to reflect the status of the light. How does st know that counter 5 relates to this device ?
- schford - 01-09-2018
[user=318]wexfordman[/user] wrote:
Quote:If this is the case, how does ST hub know the status of the device, for example, I have response 33 to turn on a light, which it does, and counter 5 is updated to reflect the status of the light. How does st know that counter 5 relates to this device ?
Did you bottom this one out? Did you need to create some sort of virtual switch in ST?
Cheers
Stuart
