New Battery - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: Problems & Troubleshooting (https://www.comfortforums.com/forum-36.html) +---- Forum: Troubles (https://www.comfortforums.com/forum-77.html) +---- Thread: New Battery (/thread-4730.html) Pages:
1
- slychiu - 08-16-2017 If you disconnect the battery, does the system power off? If so I would check the power socket that the Comfort ias connected to has mains voltage, and the connections from the transformer to the Comfort 14VAC terminal blcok - delmejo - 08-16-2017 [user=1]slychiu[/user] wrote: Quote:If you disconnect the battery, does the system power off?I disconnected the battery and the system goes off completely.The unit is connected to a mains socket using one of these https://www.cheapalarmparts.com.au/products/Transformer-Plug-Pack-18v-TF008%252dB.html The power socket itself is OK as I connected a lamp to it and the wires from this power plug seem OK in the terminal block on the main board.Do you think maybe the power plug/transformer has died?Forgot to mention this earlier but this problem seems to have come about after our street had planned power outage for maintenance work. Thanks - slychiu - 08-16-2017 The most likely culplrit is that plug in transformer If you have a multimeter measure the output wires connected to the Comfort AC In. It should be 18VAC If not just buy another - slychiu - 08-16-2017 Quote:Forgot to mention this earlier but this problem seems to have come about after our street had planned power outage for maintenance work. If power was off for a long time and the system was runnng on battery, that may have drained to battery to very low and damaged it, since the battery was already many years oldf |
