KP03 - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: KP06/KP06A/KP04A Keypads (https://www.comfortforums.com/forum-105.html) +--- Thread: KP03 (/thread-4926.html) Pages:
1
- slychiu - 04-08-2020 Measure the 12V voltage at the ketypad, It could be there is too much voltage drop along the wires to the keypad which leads to too low voltage at the keypad to power the keypad. if the votage is still 12V and power off and on ddoes ot do any good then it should be time to replace with KP04A or KP05A. KP04A and KP05A have the same fnctionality but are better than KP04 - Ian - 04-08-2020 Thanks for the reply. I will put a testmeter on the voltage, but as it has worked flawlessly for 2 years I think it unlikely. - Swiss-Toni - 04-09-2020 Contacts do become oxidised and create bad contact regardless of how long it has been working for previously. - Ian - 04-09-2020 Indeed they do - but I cleaned them! I also took out the wires and redid them. I have ordered a repalcement keypad. - Ian - 04-09-2020 New keypad installed (KP04A) and all working again. Thank you for the advice. |
