The EEPROM data is invalid - Printable Version
+--- Thread: The EEPROM data is invalid (/thread-5030.html)
Pages: 1 2 3
- slychiu - 03-20-2019
Is it always the same Virtual Node that becomes basic?
If so, can you exclude that node and add it again.
Open the Monitor IO window and let us have the content while you do a learn whether succeed or not
Can ypou also send your cclx file to support@cytech.biz
- Home - 03-20-2019
Are you using a new board with a 15VDC supply or the old 14VAC?
Hopefully you have not managed to mix the incorrect power supply with the board!
- Ian - 03-20-2019
Nope - all 12v. Combine that with it used to work!However - all suggestions welcome until I get to the bottom of the problem.
- Ian - 03-20-2019
@slychui - thank you for your continued support in trying to resolve this for me.
I have sent an email with the information.
- lwillerton - 03-25-2019
Hi Ian
Can I ask what hardware you setup as VN? and did you use HS to associate the VN with the hardware?
My Z-Wave network is 20+ items and apart from delays in the z-wave network it is solid.
I have used a fibaro door sensor v1 in the past with a VM and once I had made the association it work without issue. I will try to get a VN working in my network over the next few days to see if I have any problems.
Best Wishes
Lee
- Ian - 03-25-2019
The virtual nodes were created between Comfort and Homeseer.
My z-wave network was solid until recently and the only issues are with the replication in Comfort.
When you say VM do you mean VN?
- lwillerton - 03-26-2019
Sorry Ian yes VN. What are you trying to do with he VN?
Cheers
Lee
- Ian - 03-26-2019
I can link inputs in Comfort to virtual nodes. I can then set off events in HomeSeer when the virtual node is activated.
- Ian - 03-29-2019
@slychui - did you get my email responding to your offer?
Cheers.
Ian
- slychiu - 03-30-2019
IanI just replied by email. please check my sugestion
