Odd behaviour on prgram transfer - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: Problems & Troubleshooting (https://www.comfortforums.com/forum-36.html) +---- Forum: Troubles (https://www.comfortforums.com/forum-77.html) +---- Thread: Odd behaviour on prgram transfer (/thread-5201.html) Pages:
1
- Pgordon - 07-29-2020 I should learn to RTFM! I see there\'s a firmware history at the back of the manual, from which I see there\'s been half a dozen new releases after this one... So Chiu, can I get a drop-in firmware upgrade? ![]() Cheers Paul G. - slychiu - 07-30-2020 Sorry, Paul. RIO is not flashable, it is old technology! That is why we discontinued it. The IRIO is tge new module that has many more feaures and is flashable. http://www.comfortforums.com/forum129/4328.html - Pgordon - 07-30-2020 No worries, thanks Chiu. I\'ll see how I get on with this old tech... - like I said I only need it to support a couple of sensors for automation etc. - Swiss-Toni - 07-31-2020 Just a thought you may have to put an inline fuse between the power supply and RIO you will need to get ampere rating for the rio to protect it against over ampereage..... - Pgordon - 09-04-2020 Update... every time I transfer a program to Comfort, it goes totally mad... - it *INSISTS* on arming to night mode - I have to stand at the keypad constantly entering my code to stop it, but it keeps trying... also, it announces every zone activation. This time, the transfer started and nothing went awry for the first few percent, then the above madness, then at somewhere after 50% (I couldn\'t see exactly, as I was standing at the keypad), the madness all stopped and the last portion of the transfer continued normally. The transfer completed as it should, & the panel reset. Once complete, everything is behaving perfectly. So, this wasn\'t a one-off, every time I perform a transfer this madness happens.... I\'m running Comfigurator 3.13.5.0 which I upgraded to only the other day - so this behaviour has ocurred with the last 2 versions of the software that I\'ve run. Could it be a glitch in the Comfigurator software? - is anyone else seeing any unusual behaviour when doing a full transfer? TIA Paul G. I should add, the only thing different from before is that the RIO is now connected via KA/KB - it is not using the panel power supply as already described above... - I haven\'t tried disconnecting the RIO then doing a transfer, I\'ll give that a go when I next get an opportunity, although of course if/when I do temporarily disconnect it to test the transfer, I\'m going to get a communication failure alarm... - slychiu - 09-05-2020 It looks like something in your program may be causing it. If it happens midway thrpugh the download instead of at the end, it could be after some locations are updated, the system acts on tit. Look for the Response which arms to Night Mode and right click and check References to see what activates this.. BTW do you have Partitions? - Pgordon - 09-08-2020 Thanks Chiu, I think you might be on to something.... here\'s the references to my night mode response: [img]data:image/png;base64,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[/img] when you say \"Do I have partitions\"... - I don\'t have a partitioned system or use partitions, TBH I\'ve never even looked at that as it\'s something I definitely don\'t need AFAIK. I thought that a non-partitioned system just used partition 0 though... is that not correct? The first time I ever even looked in the partition event section in Comfigurator was after your announcement a little while ago about the bug that was deleting them upon save. I checked mine, and saw that they were indeed all NullResponse... Not having been aware of ever setting those to anything, (as I say, I\'d never looked at them previously), I checked one of my older config files (saved a few months prior) and in there I thought I saw the partition events were set as follows: [img]data:image/png;base64,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[/img] So, I reset those responses to match what I thought was the \'correct\' setting according to my earlier config file & uploaded to Comfort. However, I\'ve just been through & checked all of my older config files - every time I make a major change I save the CCLX as a new version, so I have a history of my configs going back several years - and in ALL of them, the partition responses are all Null, including the one I thought I compared against previously.. - I must have been confusing which file I had open perhaps... Anyway, I guess that\'s the problem, since it appears as though those response have always been null... I\'ve now set them back to null and I\'ll try an upload in a little while... will feed back the results. Thanks! Paul G. - slychiu - 09-08-2020 I suspect the security off, night, day, mode responses were pointing to some random response with the buggy older Comfigurator. |
