Vocab Upgrade Failure - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: Problems & Troubleshooting (https://www.comfortforums.com/forum-36.html) +---- Forum: Vocabulary Issues (https://www.comfortforums.com/forum-76.html) +---- Thread: Vocab Upgrade Failure (/thread-5267.html) Pages:
1
- slychiu - 01-06-2021 One question. How did you upgrade the vocabulary, using UCM/USB or UCM/ETH03? what is the UCM firmware version? - daniedb - 01-06-2021 It is a UCM Ethernet interface. Not sure if it is ETH03 or an older version. I am attaching a photo. The firmware version of the UCM is 7.141 currently. - slychiu - 01-07-2021 That should explain it. ETH02 does not support Vocabulary Upgrade. I suggest that you buy the ETH03 and plug in in place of ETH02. However I am not sure if the DSP could be damaged - daniedb - 01-07-2021 Ok, Thank you. I\'ll start the process with replacing the ETH02 module with ETH03 and then possibly the DSP board. Will let you know. I appreciate the support and comments. |
