- slychiu - 03-29-2025
Version 8.024
Bugs
- \"enter new code and # key\" is anounced for change/add user code on keypad after entering new code 2 times, but new code is actually accepted. bug for Toshiba only not ARM
Changes
- Fixed bug- test mode failed ACOFF (affected production test only, no difference for actual usage)
- slychiu - 04-13-2025
Version 8.027
- Fixed BUG any zone number higher than a virtual input will also effecitvely be virtual
- Fixed BUG for Toshiba only from 5/12/23 \"enter new code and # key\" is announced for change/add user code on keypad after entering new code 2 times,
RE: Firmware 8.001 to 8.027 - slychiu - 11-08-2025
Version 8.031
Bugs- actions exit, marker, invert marker did not work (old bug)
- Pabx Menu in Engineer menu (7.2) cannot announce correctly, although the PABC didigt is correctly programmed
New Features
- Detects GSM5 GSM Module. This allows HELP text to work for SMS from phones to UCM/GSM model 5. Otherwise SMS Help text will not work
Firmware 8.001 to 8.031 - slychiu - 11-08-2025
Version 8.031
- added RS232 State for ST state query
- Removed wifi function for this firmware. WIFI01 submodule plugged in to CM9001 will NOT work for this firmwarte
- fix BUG in PABX menu Engineer Menu 7.2
- fix bugs in actions 192 to 200 for actions exit, marker, invert Marker
- improved serial communication queuing of replies to multiple commands
