More than one Entry Zone - Printable Version
+--- Thread: More than one Entry Zone (/thread-643.html)
Pages: 1 2
- ident - 07-27-2012
I think we know what you experienced
In Comfort 2, if an entry door is open and you arm to Away Mode, the keypad will announce the entry door eg \"Front Door\" and repeat, instead of \"Please Exit\"
When you close the door, it arms to Away Mode
This behaviour is different from Comfort 1 for a very good reason
if there are 2 entry doors, and one or both is open, you need to know which door is open rather than hearing \"Please exit\"
In Comfort 1, if you had 2 entry doors, say front and back door, and assume the back door is open when you press the Away Key. Comfort 1 would say \"Please Exit\". If you exit through the Front Door, you would get an Arm Failure alarm
In Comfort 2, you hear the entry door or doors which are open and so you will know which door needs to be closed during exit
- Howser - 07-27-2012
[user=86]ident[/user] wrote:
Quote:We have tested the cclx file using the same firmware that you have
We can hear \"Please Exit\" when all immediate zones are closed
Did you upgrade the board to Comfort II?
what was changed?
Yes, upgraded the board from Comfort I. The cclx convert had issues, which you fixed. Those are the two things that changed.
