web server module - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: Comfort Webserver Module (OBSOLETE) (https://www.comfortforums.com/forum-49.html) +--- Thread: web server module (/thread-72.html) Pages:
1
- Guest - 04-27-2007 We just tried it out with FireFTP which appears to work well remotely and locally. Could it be some firewall or some settings on the remote router that is blocking the access? - BMagalhaes - 04-27-2007 Please advise on what ports should be configured on the Forward Router table to the CWM IP address. Tks - Guest - 04-27-2007 You should have ports 20-21 opened, but I do not suppose its the router that is connected to the CWM that is causing the problem, but rather the settings on the router of the remote PC. Some routers do have a firewall which may block ftp. - BMagalhaes - 04-27-2007 Found the problem... The FireFTP was configured as \'Passive Mode\'. As I unchecked this option the content of CWM appeared... Tks for the help! - BMagalhaes - 04-30-2007 Why does CWM opens several windows? Isn\'t it possible to have it opening in a single browser? The idea would be to have a main window where we could see the house and then selecting room (for example), CWM would change the picture on the browser! - ident - 05-01-2007 I think it has to do with certain limitations of the process Also if it has to upload the background image each time you want to go back to the image, it would be rather slow. - cetinler - 03-28-2008 [user=23]rooster2001[/user] wrote: Quote:i can change my ip adress but after press configure button its opening blank explorer page what can i do to solve this problem? I can connect to my control panel by using RS232 but i can not get an IP address from Web Server module with ethernet. On the CWM setup screen there will be not an IP. What could be the problem, why cant I see the Web Server Module? - admin - 03-29-2008 Can you disable any firewallsl you have in the network and try this again |
