Problems with Fire Alarm - Printable Version
+--- Thread: Problems with Fire Alarm (/thread-1036.html)
Pages: 1 2 3
- SteveS - 05-13-2008
What are the distinguishing marks on a LEM01 that will allow me to confirm it\'s type
- admin - 05-13-2008
There are no obvious differences looking at the LEM PCB
It is marked on the  box which it came in, or check your order
You can also give us the serialnumber and/or the stamped date code normallly \"BS.....\" with 4 numbers
Haven\'t opened the box yet this morning...
BUT
If it IS incompatible
Why does CCT9 (obviously on the LEM01) defined as zone type 26 work fine?
Surely it either works or it does NOT
No, that is not a valid conclusion. Comfort I and II logic work at different voltages, sometimes circuits may work partially or intermittently when they are outside their voltage range.  If you have Comfort II LEM with Comfort I main board then that combination is not supported and should not be used
Please see attached image.
Sorry to chase...
If I have got the wrong LEM I would like to order a replacement ASAP
Please advise
Steve
Definately Comfort II LEM, as you can make out the OP1 output board
