Connecting a PC to UCM/Eth2 - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: UCMs (https://www.comfortforums.com/forum-146.html) +---- Forum: Ethernet UCM/ETH03 (https://www.comfortforums.com/forum-113.html) +---- Forum: UCM/ETH01 & UCM/ETH02 (https://www.comfortforums.com/forum-119.html) +----- Thread: Connecting a PC to UCM/Eth2 (/thread-3484.html) |
- Guest - 04-10-2017 Thanks. I\'ve already tried with the previous network config but it didn\'t change anything to the results. - slychiu - 04-10-2017 If you have kept SW101 pressed for more than 7 seconds on power up and it still cannot work, then I suspect that the ETH02 is faulty ETH93 would be a good replacement |
