Vocab corruption? - Printable Version
+---- Forum: Vocabulary Issues (https://www.comfortforums.com/forum-76.html)
+---- Thread: Vocab corruption? (/thread-4599.html)
Pages: 1 2 3
- slychiu - 02-08-2017
We suspect the Flash which stores the words is faulty so when some words are retrived, the addresses get crossed and the wrong word is loaded to the speech engine
Or perhaos the DSP is sending the wrong addresses
In any case it looks like a hardware fault
Can you let us have the serial number(s) of the Comfort PCB
- idheath - 02-08-2017
Is the serial number only visible on the physical board?
Newer comforts may show the serial number in Module scan in Controller properties
Shows as invalid in Comfigurator. I will open it up later and let you know.
- slychiu - 02-11-2017
There are random words which are pronounced  wrongly
We suspect that it is a fault on one of the address  pins of the flash which stores the words. so when a word is retrived from the flash, it gives a dfferent word
The Comfort PCB looks like it needs to be repaired
Let us have the seriqal number
- idheath - 02-18-2017
I have the serial number now, will PM it to you.
- idheath - 05-13-2017
Only just got round to installing the replacement half card. All sorted, working now :-)
