Comfigurator 3.13.1 to 3.13.6 feedback - Printable Version
+--- Thread: Comfigurator 3.13.1 to 3.13.6 feedback (/thread-5155.html)
Pages: 1 2 3 4 5
- slychiu - 10-23-2020
Yes that was a problem with 3.13.4 where the Away, Night, Day mode responses were lost.
It was not easy to find.  3.13.5 should gave fixed all teh know problems.
Apologies for the problems caused
- caravanboy - 10-23-2020
It was definitely a problem before 3.13.4 as I only used 3.13.3 and I lost those same responses in my config at some point.
I\'m now on 3.13.5 and have manually re-added them
You should not have any problems with 3.13.5
- garym999 - 10-23-2020
I\'m sorry but I think we do. If I load a previous config that was working in an earlier version it does not migrate the response over to the Partition Events
- slychiu - 10-24-2020
Yes we will check if the next version can convert the older files.
I did not read your comments carefully:X
- slychiu - 11-14-2020
Comfigurator 3.13.6 (Beta) is available from https://www.cytech.biz/comfigurator.html
Please note that there was a previous beta with the same 3.13.6. If anyone has installed this please uninstall before installing this again. The date om the Comfiguraor 3.13.6 should be 10 Novemnet 2020
Known Bugs
wifi01 SSID  and Passcode settings do not allow spaces
Bugs Fixed
  •  Action set Virtual Input does not select Virtual Input, selects physical input instead
  •  And/OR actions are wrong for read from comfort. Now actions involving And/Or conditions after Read from Comfort will appear as Branch instructions, instead of If/Else instructions.
  • Set login partition Action error was fixed
  • Security Mode Responses and siren outputs programmed in old cclx files were not in Partition events.
  • Cbus to Comfort Output status is wrong when mapped to lighting group address. Output -1 status was shown instead of output number status
New features
  • IRIO   Analog Output Proportional + Integral Mode Changes for each Analog Output: Added Direction mode for PI control, Change text Integral time (secs) to Integral Time (samples), Add parameter Sample time (secs). Gain (K) range changed from (0 to 15.93) to (0 to 31.875)
  • IRIO Added Submodule Type 9 PT1000 (This hardware is not yet available)
  • IRIO  Added Input Type 8 applicable to PT1000 Teperature sensor. (This hardware is not yet available)
- garym999 - 11-14-2020
I can confirm that this appears to now load the partition events OK now. Thanks
- slychiu - 11-15-2020
Another problem solved  Tongue
- Home - 11-16-2020
Partitions have not been tested thoroughly.
When programming partitions NEVER do a partial download it can send comfort into an ever decreasing spiral of faults.
- TheMax74 - 12-24-2020
I confirm as well, that 3.13.6 correctly remaps the armed events.
I agee with Gary that a link in the upgrade advise window, pointing to an html page containing ALL the previous changes (and not only the latest) whould be useful. The page should contains the change history for each version, because not everyone is aware of/has installed all the step-middle versions.
