New Comfort2MQTT for Home Assistant - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Software Applications (https://www.comfortforums.com/forum-4.html) +--- Forum: Comfort with Home Assistant (https://www.comfortforums.com/forum-143.html) +--- Thread: New Comfort2MQTT for Home Assistant (/thread-5511.html) |
- Ingo - 11-25-2024 That is correct, it enriches the log entries as I cannot programmatically determine which zones, outputs, flags etc. are assigned to which device types like door, windows or lights or any other integration to Comfort. - slychiu - 11-26-2024 That is understood. Great work by koochyrat and Ingo! I will start a new topic on the steps to install the add on with home assistant on a Raspberry Pi, so that novices like me will be able to do it easily. - slychiu - 11-28-2024 quick question - why are there 2 MQTT devices; Comfort 2 Ultra and Comfort2MQTT bridge? I am trying to understand the function - Ingo - 11-28-2024 The Bridge is the software component linking Comfort to MQTT - the \'Bridge\'. Comfort is the actual device itself. - slychiu - 12-02-2024 For my new introduction and step by step guide to implementing Comfort2MQTT o a raspberry Pi, see http://www.comfortforums.com/forum27/5577.html - Introduction http://www.comfortforums.com/forum27/5572.html - Guide Part 1 http://www.comfortforums.com/forum27/5577.html - Guide Part 2 http://www.comfortforums.com/forum27/5577.html - Guide Part 3 - slychiu - 12-13-2024 Hi Ingo, I am trying to get the battery status update working. I am using the Arm Comfort PCB but when I press Battery Updtae Button, the log shows Unsupported Battery Update received; 2024-12-13 13:06:19 DEBUG D?0101E8 2024-12-13 13:06:20 DEBUG D?0102D1 2024-12-13 13:06:47 WARNING Unsupported Battery Update query received. 2024-12-13 13:07:00 WARNING Unsupported Battery Update query received. 2024-12-13 13:08:00 WARNING Unsupported Battery Update query received. 2024-12-13 13:09:00 WARNING Unsupported Battery Update query received. 2024-12-13 13:10:00 WARNING Unsupported Battery Update query received. 2024-12-13 13:10:49 DEBUG D?0101E8 2024-12-13 13:10:51 DEBUG D?0102D1 2024-12-13 13:11:00 WARNING Unsupported Battery Update query received. it happens every minute as well using the automation Is there any other setting missing from the instructions? - Ingo - 12-13-2024 Hi Chiu, Yes, that feature I coded without having the HW to test with. I gave it my best shot. You are welcome to email me the logs so I can investigate with you to come up with a solution. Ingo - Ingo - 12-14-2024 The issue was found in the Home Assistant Battery Update Automation for ARM processors. I\'ve updated the release to 1.2.5 that correctly handles HA \'quoted\' variable parameters. - slychiu - 12-15-2024 Thanks Ingo. The error message is gone, the update seems to work. The voltages can be seen in Developer Tools > States. 12.70 and 14.35. The labels seems to be swapped. Charger voltage should be 14.35 and Battery should be 12.70 ![]() But when I add the card to the dashboard, there seems to be no option to display the voltages (attributes) , it is OK and Warning which are the States which are fixed - slychiu - 12-15-2024 When I click into the Charger Status, the attribute ie voltage can be seen. Is there a threshold setting for OK and Warning states? |
