Comfort 2MQTT with Home assistant Raspbery Pi Questions and comments - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Software Applications (https://www.comfortforums.com/forum-4.html) +--- Forum: Comfort with Home Assistant (https://www.comfortforums.com/forum-143.html) +--- Thread: Comfort 2MQTT with Home assistant Raspbery Pi Questions and comments (/thread-5579.html) |
- Jon798 - 01-25-2025 Screenshot of comfort2mqtt config attached. Thanks. - Jon798 - 01-25-2025 and the direcrtory listing (Terminal addon in Home Assistant) - Jon798 - 01-25-2025 and the addon log. - Ingo - 01-25-2025 I believe you are running the HA Core version and not the full Supervised version. The Addon has not been tested or developed for the Core version. It might be in the future but not currently. - Jon798 - 01-25-2025 Yes, I am running HA OS on a Raspberry Pi (the image that is supplied through Raspberry Pi imager). Apparently itâs now the most common platform for Home Assistant. I am planning to move to HA Yellow once the CM5 module I am after comes back into stock in the UK. Would be really keen to know when the addon might be supported for the âHA OS on bare metalâ option - I am moving away from HomeSeer in a virtualised environment and aiming for a setup where someone else worries about the OS updates etc. I ended up writing my own HomeSeer plugin for Comfort and really donât want to do it again for HA! If thereâs anything I can do to help with development or testing I would be glad to help - please let me know! Thanks, Jon. - slychiu - 01-26-2025 The Add-on works for Home assistant OS (installed by RPI Imager). The only issue I have found so far is that I have not been able to see the effect of the CCLX file. I cannot see where that makes a dfference. But why would you want to have it working for a bare metal version compared to HAOS? - Jon798 - 01-26-2025 Itâs not bare metal or HAOS. Itâs HAOS running directly on Raspberry Pi or other hardware (bare metal) vs HAOS running in a Docker container under some other OS (Debian/Ubuntu etc). HA yellow is HAOS running directly on hardware and the version I am currently running is HAOS running directly on Raspberry Pi 4, both are âHAOS on bare metalâ. Iâd just like to be able to run a supported, fully featured addon as I make heavy use of Comfort to provide per-room occupancy and it would be a shame to do all the work to move to HS and then to find some breaking change in the addon with a later version that wasnât supported for my environment. - Ingo - 01-26-2025 Please try 1.4.3. I found an extraneous \" character in the file path. - slychiu - 01-27-2025 with 1.4.3 addon version, the zone name is displayed in the alarm message , in this case when the zone is open during arming. before it would only be the zone number ![]() - Jon798 - 01-27-2025 Thanks this fixes the \"file not found\" error on startup. |
