Random Communication Failures with Keypads - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: Problems & Troubleshooting (https://www.comfortforums.com/forum-36.html) +--- Thread: Random Communication Failures with Keypads (/thread-5819.html) |
RE: Random Communication Failures with Keypads - slychiu - 01-20-2026 That is correct. perhasps there is an intermittent connection problem with the keypads. Can you disconnect the keypads from the wall and separately connect them to the main comfort using short wires temporarily and check if the problem still occurs? RE: Random Communication Failures with Keypads - Howser - 02-03-2026 (01-20-2026, 08:06 AM)slychiu Wrote: That is correct. Found a loose power connection on the keypad that was causing this issue. The issue is now resolved. |
