Comfort 2 Alarm working with Home Assistant! - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Software Applications (https://www.comfortforums.com/forum-4.html) +--- Forum: Comfort with Home Assistant (https://www.comfortforums.com/forum-143.html) +--- Thread: Comfort 2 Alarm working with Home Assistant! (/thread-4879.html) |
- theshepherdmatt - 07-04-2019 Hi mate, Bit of an old thread, but is it possible to send commands to comfort from openhab? i know that the items file is reading states, but can it set the alarm via published mqtt? cheersmatt - slychiu - 07-05-2019 You would need UCM/Pi to use MQTT - theshepherdmatt - 07-05-2019 Hi Slychui, I already have koochyrat\'s python code running on my pi that is receiving mqtt messages from Comfort but I\'d like to send commands to comfort from my Pi but I don\'t know how comfort executes these commands, I think it\'s under responses but i\'ve hit a wall. Cheers - slychiu - 07-06-2019 The Comfort serial Protocol is the format of messages sent and received by Comfort which others have used to communicate with Comfort. You can download from here. https://www.cytech.biz/serial_interface_protocol.html - koochy_rat - 07-08-2019 [user=30940]theshepherdmatt[/user] wrote: Quote:Hi Slychui, Yes, using responses is the most flexible way. You can use Comfigurator to program what each response does. Then via MQTT, just set a dummy value to the response to trigger it. - theshepherdmatt - 07-08-2019 Hi Hoochy_rat, Many thanks for the code, I\'ve finally got my head around the Openhab side of MQTT and can now send commands to (via Alexa) Comfort. Cheers fella - nbexiga - 06-11-2020 HI i just configure Home Assistant and i can communicate with the comfort. now i need help with the devices and the configurations that i have currently for my devices.in the main windows , with this yaml file, i only can see ARM AWAY and ARM HOME I need to configure the way as i have in my cytech configuration , the buttons for AWAY MODE , NIGHT MODE , AND DAY MODE. Waht changes do i have to make in the yaml file from https://github.com/koochyrat/comfort2 Currently my configuration.yaml file is : #comfortalarm_control_panel: - platform: mqtt name: Comfort Alarm state_topic: \"comfort2/alarm\" command_topic: \"comfort2/alarm/set\" availability_topic: \"comfort2/alarm/online\" code_arm_required: true code_disarm_required: true payload_available: \"1\" payload_not_available: \"0\" AnyOne that can help? Thanks - koochy_rat - 06-12-2020 This is the mapping from Home assistant: Quote:if msgstr == \"ARM_HOME\": ARM_HOME is for day mode. However Home assistant\'s UI does not have night mode, you have to find a way of adding that or use a different plugin. - wexfordman - 02-05-2021 Hi koochi, So I decided to abandon my openhab installation and try and move over to HASS, and see if I could implement your solution. Of course, Ive stumbled at the first hurdle again. I have installed HASS on a RPI3B, it is HASSOS/HASSIO, so i cannot SSH into it and run the commands to install mqtt client etc. Any reccomendations I could look at to work around this ? - Ian - 02-08-2021 I came across your script on Github, I didn\'t realise it was already a discussion on here! I have it running and use it to interface to HomeSeer software - it works well. Thank you. |
