Comfigurator 3.13.1 to 3.13.6 feedback - Printable Version
+--- Thread: Comfigurator 3.13.1 to 3.13.6 feedback (/thread-5155.html)
Pages: 1 2 3 4 5
- Swiss-Toni - 12-29-2020
I was having issues with my partitions on my system esp arming/disarming responses made sure all firmware was up to date problems persisted and just down graded comfigurator too Comfigurator3.13.5 everything seems to be wroking correctly again!
- slychiu - 12-30-2020
Arming/Disarming Responses are in Partition EventsCheck that the responses you need are in there in 3.13.6If sp then they must work
- Home - 12-31-2020
Perhaps you can see some of the problems occur when you do a partial download !
It would be good to get to the bottom of all these partition issues.
- bs85 - 01-17-2021
I am unable to set input 17 as a virtual input.
When creating a responce i select zone17 from the dropdown but it will not stey selected it always goes back to zone1.
Also zone1 is now configured as a virtual input and i cannot remove it.
Comfigurator 3.13.6.0
Comfort II Ultra 7.1.75
- slychiu - 01-22-2021
Virtual Inputs cannot be created by a Response. They have to ve selected as Vietual Inuts through an external device like KNX, Modbus, Cbus etc
Sened the cclx file to support@cytech.bizwe will reset the Virtual Input for zone 1 and add zone 17 as virtual
- Home - 04-16-2021
PARTIAL DOWNLOAD - PROBLEMS 
Please be aware we are STILL experiencing big problems when certain partial downloads are triggered
The last occurrence yesterday resulted in the complete loss of vocab - the .cclx file altered to the point where we lost ALL named zones AND the home control menu1
If anybody else has experienced problems with partial download can the report it please
- caravanboy - 04-16-2021
I had problems with a partial download just under a year ago (I had repeated power failures and from memory I did an emergency \"quick\" config change to change the trouble alarm siren type). Unfortunately this resulted in my losing all my vocabulary on Comfort which terrified me. Fortunately with the help of the info on the forums I was able to get my system working again.
This doesn\'t really help you though as I wouldn\'t know what version of Comfigurator I was using at the time. But I don\'t recall any other issues with the .cclx file or anything like that
- slychiu - 04-17-2021
We dont see how partial downloads can caefore/after cclx files then please share thenuse loss of vocabulary, but if there is any b
- caravanboy - 11-07-2021
Hi, I don\'t know if this is the correct place to report Comfigurator bugs, but I have 3.13.6 and have today spotted a slightly different bug related to recent changes to the partition events...
I have a response that is used in my \'armed to night-mode\' response (and other places) - the one stored in Partition Event 0 in the config file.
In Comfigurator, if I do \"Show References\" it just says \"Partition Event 0\" which confused me at first, until I started investigating the real bug, it would be more helpfil if it told me that it was used in Partition Event 0->Arm to Night Mode (or whatever the proper name is).
The actual bug I am reporting though is that if I use Graph References on that response then it blows up with an unhandled exception.
Not critical, as I can always search the config file in a text editor, as I did today, but assume you\'ll easily be able to fix that in a future release.
- slychiu - 11-08-2021
Can you send the cclx file which has the exception?
