Comfort 2MQTT with Home assistant Raspbery Pi Questions and comments - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Software Applications (https://www.comfortforums.com/forum-4.html) +--- Forum: Comfort with Home Assistant (https://www.comfortforums.com/forum-143.html) +--- Thread: Comfort 2MQTT with Home assistant Raspbery Pi Questions and comments (/thread-5579.html) |
RE: Comfort 2MQTT with Home assistant Raspbery Pi Questions and comments - darnold - 07-10-2025 Ok, thanks...I discovered I had an IP address conflict (new router was installed last week while I was away). So, this problem is sorted. However, I now have encountered the next problem. The Comfort to MQTT gets to this point: 2025-07-10 08:04:07 INFO Comfigurator (CCLX) File detected, 272278 Bytes 2025-07-10 08:04:07 INFO Connecting to Comfort (192.168.0.252) on port 1002 2025-07-10 08:04:07 DEBUG LU0F 2025-07-10 08:04:07 INFO Comfort Login Ok - User 15 2025-07-10 08:04:07 INFO Waiting for MQTT Broker to come Online... But doesn't continue because the Mosquitto Broker is reporting that the Client is unknown. I have created a user name comfortalarm with a password in Home Assistant and the account is valid. I have also tried my own credentials but still encounter this problem. Here is the log from the Mosquitto Broker: [08:17:30] INFO: Starting mosquitto MQTT broker... 2025-07-10 08:17:30: Warning: Mosquitto should not be run as root/administrator. 2025-07-10 08:17:30: mosquitto version 2.0.21 starting 2025-07-10 08:17:30: Config loaded from /etc/mosquitto/mosquitto.conf. 2025-07-10 08:17:30: Loading plugin: /usr/share/mosquitto/go-auth.so 2025-07-10 08:17:30: ├── Username/password checking enabled. 2025-07-10 08:17:30: ├── TLS-PSK checking enabled. 2025-07-10 08:17:30: └── Extended authentication not enabled. 2025-07-10 08:17:30: Opening ipv4 listen socket on port 1883. 2025-07-10 08:17:30: Opening ipv6 listen socket on port 1883. 2025-07-10 08:17:30: Opening websockets listen socket on port 1884. 2025-07-10 08:17:30: mosquitto version 2.0.21 running 2025-07-10 08:17:30: New connection from ::1:43514 on port 1883. 2025-07-10 08:17:30: Client [08:17:31] INFO: Successfully send discovery information to Home Assistant. [08:17:31] INFO: Successfully send service information to the Supervisor. 2025-07-10 08:17:34: New connection from 172.30.32.1:47749 on port 1883. 2025-07-10 08:17:34: New client connected from 172.30.32.1:47749 as 3JDIcAmbvyuJT8YdajIOiE (p2, c1, k60, u'homeassistant'). 2025-07-10 08:18:53: New connection from 172.30.32.2:60640 on port 1883. 2025-07-10 08:18:53: Client unknown closed its connection. 2025-07-10 08:20:53: New connection from 172.30.32.2:36474 on port 1883. 2025-07-10 08:20:53: Client unknown closed its connection. A bit of an update. After changing the Timeout2 back to 2 minutes I get the following in the Comfort to MQTT log: 2025-07-10 08:04:07 INFO Waiting for MQTT Broker to come Online... 2025-07-10 08:08:12 DEBUG IP0601 2025-07-10 08:08:13 DEBUG IP0600 2025-07-10 08:14:49 DEBUG IP0301 2025-07-10 08:14:50 DEBUG IP0300 2025-07-10 08:15:35 DEBUG IP0801 2025-07-10 08:15:36 DEBUG IP0800 2025-07-10 08:15:52 DEBUG IP0601 2025-07-10 08:15:53 DEBUG IP0600 2025-07-10 08:23:43 DEBUG IP0601 2025-07-10 08:23:44 DEBUG IP0600 2025-07-10 08:23:58 DEBUG IP0301 2025-07-10 08:23:59 DEBUG IP0300 2025-07-10 08:31:55 DEBUG IP0601 2025-07-10 08:31:57 DEBUG IP0600 2025-07-10 08:35:57 DEBUG IP0301 2025-07-10 08:35:58 DEBUG IP0300 2025-07-10 08:37:05 DEBUG IP0801 2025-07-10 08:37:06 DEBUG IP0800 2025-07-10 08:38:53 DEBUG IP0501 2025-07-10 08:38:54 DEBUG IP0500 2025-07-10 08:39:05 DEBUG IP0501 2025-07-10 08:39:06 DEBUG IP0500 2025-07-10 08:39:35 DEBUG IP0501 2025-07-10 08:39:37 DEBUG IP0500 2025-07-10 08:39:44 DEBUG IP0801 2025-07-10 08:39:45 DEBUG IP0800 2025-07-10 08:41:21 ERROR Error sending command 2025-07-10 08:41:21 ERROR Keepalive check failed: [Errno 9] Bad file descriptor 2025-07-10 08:41:21 ERROR Comfort Socket Error [Errno 9] Bad file descriptor 2025-07-10 08:41:21 ERROR Lost connection to Comfort, reconnecting... 2025-07-10 08:41:31 INFO Connecting to Comfort (192.168.0.252) on port 1002 2025-07-10 08:41:31 DEBUG LU0F 2025-07-10 08:41:31 INFO Comfort Login Ok - User 15 2025-07-10 08:41:31 INFO Waiting for MQTT Broker to come Online... 2025-07-10 08:41:34 DEBUG b?00000000000000000000000000 2025-07-10 08:41:34 DEBUG Zones Bypassed: 0 2025-07-10 08:41:34 DEBUG V?FE080522400100 2025-07-10 08:41:35 INFO Comfort II ULTRA detected (Supported Firmware 8.005) 2025-07-10 08:41:35 DEBUG EL11FFFFFFFFFF 2025-07-10 08:41:35 DEBUG 0 Installed SEM(s) detected 2025-07-10 08:41:35 DEBUG Hardware Model CM9000-ULT 2025-07-10 08:41:37 DEBUG DL7FF9040001010082 2025-07-10 08:41:37 DEBUG SN0101010000 2025-07-10 08:41:37 INFO Refresh Key: 01010000 2025-07-10 08:41:37 INFO Serial Number: Invalid 2025-07-10 08:41:38 DEBUG M?000F 2025-07-10 08:41:38 INFO Security Off 2025-07-10 08:41:38 DEBUG Z?0000 2025-07-10 08:41:38 DEBUG Max. Reported Zones/Inputs: 16 2025-07-10 08:41:38 DEBUG f?000000000000000000000000000000000000000000000000000000000000000000 2025-07-10 08:41:41 DEBUG S?00 2025-07-10 08:41:41 DEBUG a?1A0000000000000000 2025-07-10 08:41:41 DEBUG r?0100100000000000000000000000000000000000000000000000000000000000000000 2025-07-10 08:41:41 DEBUG r?0110100000000000000000000000000000000000000000000000000000000000000000 2025-07-10 08:41:41 DEBUG r?0000100000010000000000000000000000000000000000000000000000000000000000 2025-07-10 08:41:41 DEBUG r?0010100000000000000000000000000000000000000000000000000000000000000000 2025-07-10 08:41:41 DEBUG r?0020100000000000000000000000000000000000000000000000000000000000000000 2025-07-10 08:41:41 DEBUG r?0030100000000000000000000000000000000000000000000000000000000000000000 2025-07-10 08:41:42 DEBUG r?0040100000000000000000000000000000000000000000000000000000000000000000 2025-07-10 08:41:42 DEBUG r?0050100000000000000000000000000000000000000000000000000000000000000000 2025-07-10 08:41:42 DEBUG r?0060100000000000000000000000000000000000000000000000000000000000000000 2025-07-10 08:41:42 DEBUG r?0070100000000000000000000000000000000000000000000000000000000000000000 2025-07-10 08:41:42 DEBUG r?0080100000000000000000000000000000000000000000000000000000000000000000 2025-07-10 08:41:42 DEBUG r?0090100000000000000000000000000000000000000000000000000000000000000000 2025-07-10 08:41:43 DEBUG r?00A0100000000000000000000000000000000000000000000000000000000000000000 2025-07-10 08:41:43 DEBUG r?00B0100000000000000000000000000000000000000000000000000000000000000000 2025-07-10 08:41:43 DEBUG r?00C0100000000000000000000000000000000000000000000000000000000000000000 2025-07-10 08:41:43 DEBUG r?00D0100000000000000000000000000000000000000000000000000000000000000000 2025-07-10 08:41:43 DEBUG r?00E0100000000000000000000000000000000000000000000000000000000000000000 2025-07-10 08:41:43 DEBUG r?00F00F000000000000000000000000000000000000000000000000000000000000 2025-07-10 08:43:28 DEBUG IP0501 2025-07-10 08:43:30 DEBUG IP0B01 2025-07-10 08:43:30 DEBUG IP0500 2025-07-10 08:43:31 DEBUG IP0B00 2025-07-10 08:43:48 DEBUG IP0501 2025-07-10 08:43:49 DEBUG IP0500 2025-07-10 08:43:54 DEBUG IP0501 2025-07-10 08:43:56 DEBUG IP0500 2025-07-10 08:44:06 DEBUG IP0B01 2025-07-10 08:44:07 DEBUG IP0B00 2025-07-10 08:49:30 DEBUG IP0601 2025-07-10 08:49:31 DEBUG IP0600 2025-07-10 08:51:35 DEBUG IP0901 2025-07-10 08:51:37 DEBUG IP0900 2025-07-10 08:52:16 DEBUG IP0801 2025-07-10 08:52:18 DEBUG IP080 RE: Comfort 2MQTT with Home assistant Raspbery Pi Questions and comments - darnold - 07-11-2025 So I continue to receive a series of DEBUG IPxxxx messages with the occasional DEBUG OK message in the Comfort to MQTT log and New connection from 172.30.32,2:xxxxx followed immediately by Client unknown closed its connection messages in the Mosquitto broker log. Neither Comfort II Ultra (MQTT client) nor the Comfort2MTTBridge (MQTT client) appear as Devices. So not sure why I am unable to get things working. RE: Comfort 2MQTT with Home assistant Raspbery Pi Questions and comments - darnold - 07-11-2025 Ok so after going over everything in fine detail I noticed that somehow the port number in the Comfort to MQTT configuration was set to 1882 instead of 1883…now working. Apologies for all the noise on the thread. |
