System would not disarm - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: Problems & Troubleshooting (https://www.comfortforums.com/forum-36.html) +---- Forum: Arming and Disarming (https://www.comfortforums.com/forum-72.html) +---- Thread: System would not disarm (/thread-1012.html) |
- dcrera - 04-07-2008 Hi, I had an incident where a guest decided to wander around the house in the early hours of the morning while the system was in Night mode. When I got to the keypad, my guest was \'trying\' to disarm the system (yeah). I am not sure what de did but I could not disarm the system. I had to disconnect the battery and mains to recover the system. Any ideas as to why I could not recover the system on the keypad ? Thanks - admin - 04-07-2008 Suspicious sort of guest isnt he ?When you enter a wrong code too many times, the system will generate a Sign in Tamper and lock out the code. Check the event log and see if the Sign in Tamper event was recorded |
