Serial UCM - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: Questions on Using Comfort (https://www.comfortforums.com/forum-159.html) +--- Thread: Serial UCM (/thread-1078.html) |
- Electronia - 05-31-2008 Hi How can I upgrade my Serial UCM firmware? It is currently ver 5.62 and to upload the latest voice files it must be ver 5.92 or later. Kobus - slychiu - 06-01-2008 You can upgrade by buying the IC01-UCM. This replaces the microcontroller on the UCM labelled with the firmware. You will need a PLCC IC Extractor to remove the old IC from its sockets If you have Comfort II, consider buying a new UCM05 as that allows Comfort firmware to be upgraded. You also need the UCM05 to download a Comfort II vocfabulary - Electronia - 06-01-2008 Thank you for your quick responce Kobus |
