Comfort Mother Board - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: Questions on Using Comfort (https://www.comfortforums.com/forum-159.html) +--- Thread: Comfort Mother Board (/thread-1085.html) |
- Electronia - 06-06-2008 Hi every1 I have to work on a older Comfort board, the label on the outside refers to a Minder Pro. The Legent on the board reads \"PC01-001E\". Its is not a split board like the Ultra II and it has the inputs on the bottom right and the outputs on the bottom left. Q What board version is it? (Entry, Pro, Optimum, Ultra...) Q What file system should be used? (17, 34) Q Can I connect a 16 input LEM to it, and what would the product code be for this LEM Kobus 083 415 3333 - slychiu - 06-06-2008 This is a MinderPro Mk 1, also known as Comfort I PRO. The file system is 18 You can connect a 16 zone LEM to it, part number is LEM03 or for Clipsal, 5350EXL16/0 |
