Creating a time program to turn off chime. - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: Questions on Using Comfort (https://www.comfortforums.com/forum-159.html) +--- Thread: Creating a time program to turn off chime. (/thread-1087.html) |
- SteveS - 06-07-2008 Hi, please could someone help my thought process on this one. Most important to note - I am programming an Ultra 9000 using the engineer menu ( a UCM is a soon to be made upgrade) I have a sensor in an outbuilding which is set up as a zone type five with an \'on\' response that causes the system (keypads) to chime in system off mode. I would like to disable the chimes for, say 20 mins, by a single - or pair of keystrokes or some other means that does not requires a user sign in. Alternatively it might be just as effective to reverse (turn off) the response on the zone but again only for a limited period. Any pointers would be appreciated. Thanks in anticipation Steve - garym999 - 06-17-2008 Wait until you get your UCM and that will make programming a whole lot easier ![]() I\'d use the additional contact to run a response that starts a timer runing for the 20 minutes; Do NullResponse After 1200 Seconds Using Timer01 (194,1,4,176,0,0, 255) Then in the response for the outbuilding add a test to see if the timer is running; If SecurityMode = SecurityOff Then If Timer Timer01 = 0 Then Siren Chime End If End If (73,0, 115,6, 86,1, 115,2, 64,15, 255) Think that should work |
