Programming Comfort? - Printable Version
+--- Thread: Programming Comfort? (/thread-1090.html)
- benmc - 06-08-2008
All
My Comfort system arrived and I have connected connected it on the bench to test it was working. All seemed to work well here.
I also managed to get a connection to my network from the UCM/ETH. From here I got Comfigurator and WizComfort working.
Now things get a bit confusing.
Where do I start to program the system?
From what I can tell if I added another UCM and Keypad here is the sequence of events
1. Setup Jumpers on UCM/Keypad
2. Make connection from UCM/Keypad to Comfort
3. Reboot Comfort - May not be 100% necessary
4. Start Comfigurator and make changes to the file (add keypad and UCM)
5. Download now config to Comfort
Have I got this right? - You have to match the the Comfigurator you download to Comfort to the physical setup.
Cheers
Ben
- hendy - 06-09-2008
From what I see, you have got it right; the Comfort settings have to match with the physical setup.
