Action 200 with Comfort I - Printable Version
+--- Thread: Action 200 with Comfort I (/thread-1095.html)
- Barn1994 - 06-16-2008
I\'ve been trying to get a DM02 working with Comfort I for some time now.  I need to control the relay on the DM02 for gate control, but it appears that Action 200 was added only in firmware that isn\'t supported on Comfort I.  Have I got this right?  If not, which firmware do I need?
Is there any chance that the audio functions on the DM02 don\'t work with Comfort I? I\'ve tried a couple of these with a couple of Fermax intercoms, but have had no luck.
Ben
- slychiu - 06-17-2008
The Open Door action was only added in Comfort II firmware so it is not supported by Comfort I. You can still use regular Comfort outputs to open the gate or door in Comfort I
