IP webserver lost - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: Comfort Webserver Module (OBSOLETE) (https://www.comfortforums.com/forum-49.html) +--- Thread: IP webserver lost (/thread-1103.html) |
- dax - 07-03-2008 I chang Ip 10.0.0.16 to 192.168.0.14 by http://10.0.0.16/adminFM.htm after restart webserver i can not connect to webserver on ip 10.0.0.16 and 192.168.0.14 How to set it? Regend - slychiu - 07-04-2008 Are you able to see the IP address of the CWM using the DS Manager? Have you used the DS Manager to configure the IP address and Port number? Could you firewall have prevented access to the IP address? - slychiu - 07-04-2008 Sorry I meant CWM Setup in the above post, not DS Manager which is for UCM/Ethernet This post has been moved to the Comfort Webserver forum |
