UCM RS232 speed - 4800 ? - Printable Version
+--- Thread: UCM RS232 speed - 4800 ? (/thread-1276.html)
- palmlodge - 12-23-2008
Can the RS232 port on the UCM be set to 4800bps ? Or is it 9600 only ?
Specifically, can Comfort talk :
4800bd, 8 bits data, no parity, 2 stop bits.
- admin - 12-24-2008
We have a different version in which the shunts set thye baud rate, 4800 being one of the options. This is not available in the standard UCM as it would probably lead to many support calls due to the wrong setting of the baud rate
