IRD01 Wiring - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: Questions on Using Comfort (https://www.comfortforums.com/forum-159.html) +--- Thread: IRD01 Wiring (/thread-1279.html) |
- engmoabel - 12-25-2008 please confirm the IRD01 wiring terminal, J2-is connected to any RIO input (RX). J2- GND is connected to the COM of the same Rx input. J1-LED is connected to an Output on the RIO( ex. the other block output which TX connected). J1-TX is connected to an output on the RIO. J1- 12v is connected to direct 12V on the RIO. that wiring leave the COM pin at output block of (TX&LED) without wiring !! Is that correct? Thanks - admin - 12-25-2008 The Centre terminal of the Output terminal blocks are 12V so it is not necessary to connect it to the IRD as 12V is already connected between IRD and RIO |
