Italian Vocab - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: Questions on Using Comfort (https://www.comfortforums.com/forum-159.html) +--- Thread: Italian Vocab (/thread-1280.html) |
- admin - 12-30-2008 Hello, i\'ve a custom, self made, italian dictionary. Do i need to re-compile it? If yes, what version of \"VoiceProc\" can i use to re-compile it? Thanks. ------------------------------------------------------------- This was reposted from another forum ---------------------------------------------------------------- Do you mean that you have created the Italian voice for Comfort 1? If so you need to reprocess it as there are new sentences, and you need to use VoiceProc and VoicePlay downloaded from http:/www.cytech.biz/software.html Instructions for VoiceProc are from https://www.cytech.biz/Default.aspx?cmd=sQ0OYE9X66w%2b0P%2bAcFsmAI3j73Rwtfrj&fileid=192&dcid=8&pageindex= - TheMax74 - 12-30-2008 Not for Comfort1. The Italian vocab is for Comfort 2 Ultra. Thanks. - admin - 12-30-2008 You should not need to recompile it, if you have done it already However please note that the vocabulary is version 28. If yours is not updated then you will need to update the new sentences added in version 28 Send an email to support@cytech.biz if you need further info about this - TheMax74 - 12-30-2008 I\'ts ok. I need to add some words, so i need the voiceproc, but the VoiceProc.zip in the cytech\'s download page, has an i/o error. I can\'t decompress the zip. Can you fix this issue? Thank you. - admin - 12-30-2008 I just tested the voiceproc zip file, and it was able to unzip with no problems Can you download and try again and let me know what the error message is? - TheMax74 - 12-30-2008 Ok, tried several times, with no luck, from here https://www.cytech.biz/Downloads/Files/72/VOICEPROC.zip Unexpected end of archive. Note the CRC in the attached image. - admin - 12-30-2008 I have sent the .msi file to your email, pls check - TheMax74 - 01-02-2009 Thanks. I cannot hear the new menu \"7 for Volume\". I need, if possible, all the new .tab and all the config files used for the new english vocabulary. I will check with mines and i will add the new sentences and phrases. I have only the new cs-wl-std.cfg, that is in the ccl5140.zip. Thank you! - admin - 01-02-2009 The zipped files for kate28 is attached Can you send us the vocabulary when you have completed? Thanks - TheMax74 - 01-02-2009 Yes, roger. Off course. |
