Arm to Night Mode when leaving? - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: Questions on Using Comfort (https://www.comfortforums.com/forum-159.html) +--- Thread: Arm to Night Mode when leaving? (/thread-1406.html) |
- Ingo - 03-15-2009 Hi, Has anyone tried to arm to Night Mode when leaving the house? I have a situation where I frequently have to work after hours. When I leave the house I don\'t want to wake my girlfriend to ask her to arm the system again, I want to press the Night Mode button and leave the same way as I would leave and arm into Away Mode. Is this possible? On returning, the system will be armed in Night Mode, my opening the garage door will trigger the entry timer so I can enter normally and disable the alarm once inside. Ingo - ident - 03-15-2009 You can arm to Night mode when leaving the home You need to be careful that the Night Exit time is long enough for you to leave the house When you open the door, the system will annnounce the zone which may wake your girlfriend unless the keypad is far enough from the room When you return and open the door, the entry delay starts to allow you to disarm - Ingo - 03-15-2009 That will work. I just have to increase the exit time and again read the \'Silent Arming\' thread from a couple of weeks ago. Thanks. |
