KP Firmware - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: Questions on Using Comfort (https://www.comfortforums.com/forum-159.html) +--- Thread: KP Firmware (/thread-1914.html) |
- juwi_uk - 07-10-2010 Hi Is there a way to get the keypad firmware version to display temporarily on the keypad LCD via a keypad key sequence? When my comfort resets the firmware flashes on the LCD for a fraction of a second (no time to read it) before the normal date/time/Security Off messages display and clears the firmware version. Regards Julian - ident - 07-10-2010 Yes Press # and 9 simultaneouly - juwi_uk - 07-10-2010 Tried that and it does nothing. What am I doing wrong? J - ident - 07-10-2010 Remove power and disconnect the KA/KB then apply power This shows the firmware - juwi_uk - 07-11-2010 OK, sounds like a plan. Just a pain to have to take the system apart (covers of, disconnection things, powering alarm) just to be able to get at the version number. |
