Phone Trouble - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: Problems & Troubleshooting (https://www.comfortforums.com/forum-36.html) +---- Forum: Troubles (https://www.comfortforums.com/forum-77.html) +---- Thread: Phone Trouble (/thread-1931.html) |
- nickbg - 07-23-2010 Hi, I am hoping that someone maybe able to help...... Whenever I pick up the phone to make or receive a call, after say 1 minute the comfort keypads start bleeping for about 10 seconds. Has anyone experienced this or got any ideas what could be causing it ? Many Thanks Nick - slychiu - 07-23-2010 You should look the the LCD display which shows the cause of the problem in the his \"Phine Trouble\" The reason you are getting the trouble alarm when you use the phone is because you have connected the house phones in parallel with TEL IN on Comfort. Telephones must be connected to TEL OUT not TEL IN This is very important because Comfort must be able to seize the line to cut off the local phones when it has to dial out in the event of an alarm Refer to the Installation Manual on telephone line connection |
