UCM ID's and Order - Printable Version
+--- Thread: UCM ID's and Order (/thread-252.html)
- Stephen Coates - 10-23-2006
UCM ID\'s and Order
I have both a RS232 (for program download) and a CWM UCM.
I wish to use the CWM as the main UCM for download.
Three reasons:
1. It can do it on TCPIP
2. It reduces cost as the RS232 is not required.
3. It saves space in the installation.
Is the following possible.
I confiugre the RS232 as ID 1
The CWM as 2
All others 4..5 e.t.c
I use the RS232 for the initial Download and configuration, but then
disconnect it physically from the system.
This leaves the CWM as the 1st UCM but at ID 2.
I can then reconnect the RS232 UCM as and when required.
- Guest - 10-24-2006
Yes, that will work fine. In fact, I believe a number of installers do it that way.
