Keypad not announcing Zones in Security Check - Printable Version
+---- Thread: Keypad not announcing Zones in Security Check (/thread-3044.html)
- Dash 8 - 08-27-2012
Hi There
My keypad use to announce the zone numbers in the security check mode under the engineering menu.
It does not do that anymore, not sure why. I have received my UCM/Ethernet board and have been playing with comfigurator, maybe I have changed some setting.
Any help will be appreciated.
- slychiu - 08-28-2012
You may have changed some settings in the cclx file
Try comparing with the default template (open File > New)
If you still have problems send the cclx file to support@cytech.biz for checking
- Dash 8 - 08-28-2012
Thanks, problem sorted. Downloaded blank template, and working again.
My other problem was the volume control on the side of keypad Confusedhock: did not see that, was turned all the way down.
Fred
