Vocab - Printable Version
+--- Thread: Vocab (/thread-3139.html)
- jbarne41 - 11-01-2012
Apologies in advance, my tiny brain cannot seem to understand the instructions for Voiceproc.
I simply want to replace a few words in the Kate Vocab, i.e Replace Jacuzzi with Stable and  Yard with Shed.
I cannot see how to get the wav files into DAT the File Directory so they can be seen in Voicpro.
Have been trying to work it out using the Myma set of files as I haven\'t got the ones for Kate.
I open the Myma36.ini in voicepro followed the instructions but cannot see the word \'Stable \'in the dropdown list under the change user words tab. Stable.wav is present in the Myma_Highpass.wvd Directory but not in the Playdat directory and there is not Stable.dat in the Myma.dat Directory.
Can you point me in the right direction as the instructions for the Voiceproc are not easy to understand.
Also if I can get it to work on Myma where can I download all the files for the latest Kate. The Comfort website only has the Bin file.
Thanks in advance
Joules
- ident - 11-02-2012
They dont write good instructions.
To use VoiceProc, first open an ini file, eg myma36.ini
It looks like this
VocabNo=05
VocustNo=255
VocSysVer=36
VocUserVer=1
VocTextVer=2
LCDVer=3
WavesDir=myma_Highpass.wvd
CompressedDir=myma.dat
VCD_Quality=mid
VocabularyFileName=myma36.bin
SentencesFileName=sentence36.tab
LCDFileName=lcdkp_v34.cfg
MaxSentenceLength=10
NumOfSysWords=207
SetVol=0.6
TranslationFileName=translat36.tab
NumOfUserWords=141
UserFileName=resid36.tab
NumOfTables=5
[Tables]
Table0FileName=newtab0.tab
Table1FileName=newtab1.tab
Table2FileName=newtab2.tab
Table3FileName=newtab3.tab
Table4FileName=number4.tab
The user words are in a file specified by UserFileName, which is resid36.tab in the example
You can make a new file by copying resid36.tab and making changes to the words you need.
resid.tab looks like this
0   WORD_NUL0 NUL0        ;1st word must be NULL
1   WORD_AIRCON Airconditioner
2   WORD_BACK Back
3   WORD_BALCONY Balcony
4   WORD_BASEMENT Basement
138 WORD_WASH Wash
139 WORD_WORKSHOP Workshop
140 WORD_PATIO Patio
eg if you change 140 to stable, then
140 WORD_STABLE stable
you must have a file called stable.wav in the wvd folder in WavesDir,  eg WavesDir= myma_Highpass.wvd
You can use words from myma or kate if the word is not found in one as substituing a word from another person should not be noticeable in many cases
The number of words in the above is 141 so  NumOfUserWords=141
You should make a new .ini file and load that in VoiceProc
Run VoiceProc and it should give you the error messages if any eg missing files
It creates the bin file and a cfg file with the same name as the ini file eg myma36.cfg. This is the wordlist
Rename the cfg file to newengwl.cfg and copy to the comfigurator\\config folder
We will try to upload the kate files to the website later
- jbarne41 - 11-05-2012
Ident, Many thanks for the Response,
Have now created my Bin & cfg File, haven\'t uploaded using Configurator yet, just wanted to check a couple of things:
1) I have changed 3 Words - Attic with Stable, Lobby with Shed and Foyer with Barn. The Wav files for theses were already available, will these words be available for the LCD text on the keypad or do I need to do something else to facilitate this?
2) I presume I upload the files into comfort using the Configurator upgrade Vocab option in the Transfer Menu. - If I do get a problem would it simply be a case of uploading the original file to get back to how it was?
Joules
- ident - 11-05-2012
The new words will automatically be sent to the Keypad LCD
You can always revert to the older bin file
However the Vocab Upgrade takes more than 20 minutes and may sometimes have an error. You must re do the transfer > Vocab upgrade if this happens
Cheers,
Will give it a go tonight and let you know how it goes.
Joules
- jbarne41 - 11-07-2012
Hi Ident,
Many thanks for the help, uploaded the file and all appears to working Ok.
Simple when you know how!!
Next thing is to record a couple of words which are not in the Kate Wav set and create a new .bin.
Maybe posting again later as I still have a couple of outstanding issues from when I upgraded that I never got round to sorting.
Cheers
Joules
- juwi_uk - 11-07-2012
So in order to record new words, are you doing a good Kate impersonation then too, or is Kate going to suddenly switch accents/sex as she reads out a phrase?
You can rent yourself out if your impersonations are good and if you team up with a Myma \"sound-a-likey\" then who knows, the sky\'s the limit!
Big Grin
One job the wife can actualy do....if I ask nicely. Wink
If I try it might sound like Kate has become a docker on 50 fags a day!! Big Grin
