UCM/CBUS stops broadcasting Zone Statuses - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Third Party (interfacing to Comfort) (https://www.comfortforums.com/forum-5.html) +--- Forum: CBus (https://www.comfortforums.com/forum-11.html) +---- Forum: UCM/CBUS Problems (https://www.comfortforums.com/forum-120.html) +---- Thread: UCM/CBUS stops broadcasting Zone Statuses (/thread-3309.html) Pages:
1
- ident - 06-10-2013 [user=14]Howser[/user] wrote: Quote:Two days ago, I was about to announce that this problem seems to be resolved, but decided to wait till the last day of the Month.Did you do a scheduled reset of the UCM using RS1x to the ID? It still depends when the problem ocurs, ie if you reset at midniight and the prioblem happens after that then you will still see it - Howser - 06-10-2013 [user=86]ident[/user] wrote: Quote:Did you do a scheduled reset of the UCM using RS1x to the ID? I had schedules that Resets the Module (Action 118) at midnight and 17:00. I started with just the midnight schedule, and then the 17:00. At this point I have the Reset done in the Hourly Response. It has reduced the occurrence significantly, but it still occurs. - ident - 06-10-2013 what are the state of the leds on the UCM/Cbus when this occurs? RDY, BUSY1, BUSY2, ERR? - Howser - 06-10-2013 Will have to check the next time this occurs. I will remove the Reset logic and report back when it occurs. - Howser - 07-26-2013 [user=86]ident[/user] wrote: Quote:what are the state of the leds on the UCM/Cbus when this occurs? Eventually, the issue reoccurred. The only LED which was ON was RDY. BUSY1, BUSY2 & ERR were all OFF. - ident - 07-27-2013 So from June 10 to July 26 it did not happen even without any reset response? - Howser - 07-29-2013 [user=86]ident[/user] wrote: Quote:So from June 10 to July 26 it did not happen even without any reset response? Not quite, I had to load configuration changes in-between, the last being on the 19 July. - Howser - 10-18-2013 From end of July, the issue re-occurred last night. Not sure what to make of this. - ident - 10-19-2013 I think this may be caused by some event on cbus since it is so irregular The other thing I would suggest is to change the Cbus SIM module and see if the problem completely disappears as Ingo suggests - Howser - 10-19-2013 Will do that and report back my findings. |
