ULT 7.053 to 7.057 (Beta) - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: Firmware History (https://www.comfortforums.com/forum-60.html) +---- Forum: Comfort Firmware (https://www.comfortforums.com/forum-79.html) +---- Thread: ULT 7.053 to 7.057 (Beta) (/thread-3778.html) |
- ident - 04-19-2014 Ultra 7.053 beta can be downloaded for testing from https://www.cytech.biz/comfort_ultra_firmware.html?category_id=101 The changes are
Known Issue
- ident - 04-26-2014 ULT 7.055 (beta) can be downloaded from https://www.cytech.biz/comfort_ultra_firmware.html?category_id=101 This fixes a bug that scanning of Invalid IDs (via the u? command) did not give a valid reply. It improves scanning of old models of Keypads and Door stations which did not recognise the u? scanning command. In previous versions, if the old keypads and DP03 are not polled by Comfort due to the number of Modules not including that ID, these old models were not detected by Comfigurator scan. You had to add the keypad or door station manually and write to Comfigurator. Once the models are polled, then the Scan by Comfigurator will detect these old models With this firmware old models of Keypads and Door stations can be detected by scanning even if they are not polled Known Issue
- ident - 05-03-2014 ULT 7.056 Beta can be downloaded from https://www.cytech.biz/comfort_ultra_firmware.html?category_id=101 Changes are Bugs Fixed
Improvements
- ident - 05-21-2014 ULT 7.057 Beta can be tested at the above link The changes are
- ident - 05-22-2014 ULT 7.057 has been released. See summary of changes in http://www.comfortforums.com/forum79/3815.html This fixes the problem of extra keypads 9 to 15 appearing after a scan Please upgrade by right clicking on the Controller and selecting \"Check for Updates\" if you are connected to the Internet You can also download the firmware by right clicking and selecting \"Download Firmware Upgrade\" and later \"Upgrade Firmware from Local File\" ![]() |
