Announcing words through speaker terminal - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: Questions on Using Comfort (https://www.comfortforums.com/forum-159.html) +--- Thread: Announcing words through speaker terminal (/thread-3827.html) |
- Home - 05-28-2014 Hi, I was wondering whether it is possible to announce vocabulary through the speaker terminals on the main comfort panel (e.g. not just through the keypads, which can be turned down etc). As an example, it would be very good to do this to easily distinguish between a chime for the front door and the back door. Thanks! - ident - 05-29-2014 The speaker output is only connected to the siren sounds, and not the voice generation so Voice and announcements cannot ne heard from that The speaker sounds cannot be disabled unlike keypads so it may be an annoyance for many customers - Home - 05-29-2014 Are you able to add this as a feature at some time please. Even a tick box in the software would be good...... - ident - 05-29-2014 That would require a major change in the hardware and re-layout of the pcb and require an increase in cost, so less a significant number of users find this useful, it may not be worthwhile - Pgordon - 11-23-2014 Couldn\'t this be done with a UCM & Audio submodule? - then an audio feed that duplicates the KP audio is available right? - just plug in some PC speakers, or connect to an audio input on an external amplifier, or even a PC... P. - slychiu - 11-23-2014 Yes, in fact the UCM with Audio AUD01 plug in is meant to announce just like a keypad. The speaker output is connected to an amplifier The earlier question or request was to have voice through the Speaker terminals, and this is not possible with the current design |
