New ComfortClient - Printable Version
+--- Forum: ComfortClient (https://www.comfortforums.com/forum-65.html)
+--- Thread: New ComfortClient (/thread-3851.html)
- juwi_uk - 06-08-2014
For all registered users I\'m pleased to announce a new maintenance release; 4.1.3.5.
This is a minor release just to fix a couple of issues found in the last version.
The full list of changes is below.
Hope you enjoy.
Bug Fixes/Changes
  • Cbus1 format Template ClickResponses did not decode correctly in Floorplan Editor object properties when the Action was of “switch” type; the Application would default to “Lighting”.
  • Fixed “Object not set to an Instance of an object” error in log file during load of Connector Services.
  • During connection retries (Ethernet) the UI state is now changed to lock out any buttons/menu options that would otherwise try to use the failed connection (Send Command, System Information, Refresh etc).
New Features
  • The Home Control menu now supports right-click on a node action to execute it.
- juwi_uk - 06-14-2014
It\'s a bit disappointing there hasn\'t been much of a take-up for the latest versions of ComfortClient amongst the community.
I assume you are not interested in supporting 3rd party integrations then!
That\'s a shame as it does have a bearing on my commitment and enthusiasm.
