Requirements - community edition - Printable Version
+--- Thread: Requirements - community edition (/thread-4620.html)
- mattbrain - 02-01-2017
Applicable to version 1.0.0
In order to get a community version up an running you will need the following equipment / configuration:
1. Raspberry Pi Model B, version 1, 2 or 3.
2. Power Supply for Raspberry Pi.
3. SD Card for Raspberry Pi (4GB+)
4. UCM/Eth or UCM/Eth2 or UCM/Eth3.
5. Samsung SmartThings hub.
6. Ethernet cables and switch to connect the UCM, Raspberry Pi and SmartThings hub to your home network.
7. A broadband internet connection to your home network.
You will also need a PC (Windows, Mac or Linux) and a SmartPhone (Android or iOS) to configure and use the system.
