Where is DP MIC/VOICE connection on new boards? - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: Questions on Installation and Connection (https://www.comfortforums.com/forum-123.html) +--- Thread: Where is DP MIC/VOICE connection on new boards? (/thread-5237.html) |
- Tas - 10-17-2020 I have old board which I was trying to replace because LP51,LP52 have blown and I figured I might as well upgrade the board instead of messing about with soldering. However half-way through I noticed that the DP connection for MIC/Voice is not present on the new board (or I can\'t see it). The old board has a door phone module connected to a Fermax door entry system. Is there a way to connect the new board or is there something else I need to do? Many thanks,Tas - slychiu - 10-18-2020 On CM9001, the DSI01 plug in submodule includes the Ringer, Door station Mic/Voice, and Local Telephone support circuits, see https://www.cytech.biz/product_details.php?item_id=498 which includes the DSI01 manual download. This offloads the circuits and makes the CM9001 lower cost for those who do not need these features - Tas - 10-21-2020 Thanks, that explains the differences. How can I find my exact board model. On the DSI01 page on this forum the CM9001 board has a switch, K51, which needs to be set when installing the DSI01, however my board does not have this switch. I purchased the board just a couple of months ago. Many thanks, - slychiu - 10-22-2020 The board model is not printed in the PCB. The main visuakl difference CM9001 lacks the large heatsink and uses a DC Power supply instead of a transformer. The new power suppy is ligher and more efficient. ![]() You can also find out the model by doing Scan for modules in Comfigurator K51 is no longer needed. the manual should be corrected. It has been replaced by a 2 x shunt which is plugged in to the socket where the DSI01 should be plugged in, You have to remove the shunt in order to plug in DSI01.. If you do get DSI01, kepp that shunt i case you remove DSI01 on future - Tas - 10-22-2020 Ok. I see the shunt now. Thank you for the explanation |
