3.3v feed - Printable Version
+--- Thread: 3.3v feed (/thread-553.html)
- palmlodge - 04-16-2007
Is there a 3.3v volt feed on Comfort I can take to a very VERY small IR board (not a Comfort board)
There is a IR learning kit for about $20, 3.3v input, then use that to trigger a relay to go back into a Zone. Will support leanring any remote to produce an on/off
- ident - 04-17-2007
3.3 Volts is not available on any connector. It is supplied to internal circuits. Normally when you want to have other voltages to supply to external circuitry you would take it from 12V and have a regulator circuit that would drop the voltage to the required value. This way the Comfort board is protected against overload, shorts etc
